190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
1991 190E 228K - Replace or dunk radiator?
Old Sep 2, 2013 | 06:17 PM
Rauhbatz's Avatar
2007 ML 350 - VIN 4JGBB86E17A211020
Geeetings MB World readers...
Over the past few years I have put posts out here regarding how my 190E heats up (except in winter) standing stiull/slow traffic after it has been run on the highway. Ive tried multiple flushes, water wetter and other approaches to help with cooling...so after 228K miles I think Im ready to take the next big step.
I was curious if I should take the radiator to a shop for a complete dunk cleaning or just replace the radiator. Don't know where I can find a new one but Im sure my mechanic can locate one.
Any steer on next steps and/or pricing would be welcome...I'm likely going to try the replacement route as this car will be likely my daughter's high school ride!
Old Sep 2, 2013 | 07:03 PM
Bob338's Avatar
'85 190D , '12 E350 BlueTec, '13 GLK 250 BlueTec
It likely will cost you as much to rod out the radiator as it will to replace. I replaced mine with a Nissens (sp) that ran right around $200. That was about 8 years ago and I've never looked back. Believe you can get the replacement at Arizona Auto Haus. May be a bit more now. I've been totally satisfied.
Presume you've also checked/replaced thermostat and verified the fans are working properly.
Old Sep 2, 2013 | 08:54 PM
Rauhbatz's Avatar
Smile Bob 338 ---thanks for the advice
Thanks for the insights on the 190E radiator...I think I will go plunk down the change to get a new one; I think the Japanese components firm Nissin/Nissen would be a good place to start.
Thermostat and water pump (my second!) replaced last year....fan does come on ok. Overall the temps are good except in hot weather if it is standing or moving slow; points to a heat transfer issue which usually means the radiator is at fault. Many hot ATL summers and Ohio winters have no doubt accellerated the degradation....
If it was just going to be my airport car I would leave things as is...but with the prospect of my daughter driving it I need to get the cooling issue resolved.
Thanks! Will report back how things go
