190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
1986 190e 16v hydrolocked
Old Nov 7, 2013 | 12:35 PM
Sagetucker1's Avatar
1986 Mercedes 190e Cosworth
I recently purchased a 190e and I have not figured out what is wrong with it. I am new to the Mercedes family and don't have a good grasp on how these fuel systems work. I found that the fuel pump was bad and filter was clogged which I changed. After that the pump would not stop running and I hydrolocked(or fuel locked) the #4 cyl with fuel. I replaced the relay hoping it would fix it but dumped so much fuel in the first time I cranked it that it hydrolocked the eng again. Any help would be greatly appreciated.
Old Jan 20, 2014 | 12:21 AM
LEISTUNG1's Avatar
Former Vendor of MBWorld
95 E320 Sportline/ 86 190E 2.3-16/ 05 C55
IF YOU PULL OUT THE SPARK PLUGS CAN YOU TURN THE MOTOR OVER BY HAND? IF NOT WELL ENGINE IS COMING OUT. IF YOU CAN THE ONLY WAY THAT MUCH FUEL COULD BE PUMPED INTO THE CYLINDER IS IF THE INJECTOR IS STUCK OPEN. THOSE INJECTORS ARE MECHANICAL AND OPEN AT A CERTAIN PRESSURE IF ONE STICKS OPEN THEN IT JUST KEEPS FLOWING.
