New Member - Help Please!!!
I joined the site because I need to put another engine in my car and I have the new engine almost all put together, but I need to put the head on at this point...
Can someone please help me as far as how I set the timing chain?
I see that there cog on the end of the CAM shaft has a dowel pin with an arrow pointing to it, and I also see that there is a pin in the harmonic balancer/crank pulley that looks to be "top dead center".
I'm pretty confident that my crank shaft is positioned correctly, with my numbers 1 and 6 cylinders up. I just need to get my cam shaft in the appropriate position.
Please help me!!!
Thank you so much in advance.
