190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
93 190e has light brown gunk in coolant res
Old May 20, 2015 | 02:12 PM
s190e's Avatar
1993 Mercedes Benz 190E 2.6L
Exclamation 93 190e has light brown gunk in coolant res
I noticed there is light brown gunk in my coolant overflow tank. I see a lot of threads that jump to head gasket but have also seen a few other things that can cause this. Is there a way to be sure if it is the head gasket or crack in the block? I have drained all the coolant and filled with water, then started the car and allowed it to warm up, them using the drain in the front bumper, I drained the water out. I repeated this about 10 times and each time the water comes out clear until it gets to the end of draining at which point it becomes the sludge. The car runs and drives good and doesn't overheat, also the oil is clean with no sign of coolant in it. If possible I would like to either validate of eliminate the head gasket and cracked block possibility. Any thoughts or advise? Thanks
Old Jun 11, 2015 | 04:52 AM
lsmalley2's Avatar
w201
Bar's stop leak pellets.
Old Jun 2, 2016 | 12:34 PM
reverandjeff's Avatar
1991 190e 2.3
Did you flush it out with engine flush? If not the sludge is still lurking and you won't be able to tell for sure. Most likely a small head gasket leak though, and i had one with a massive leak that turned the coolant into chocolate foamy sludge but that thing still ran fine.. LOL
