FS: (CO) 1987 190 2.3 16v
VIDEO: https://vimeo.com/169937922
Text me for more info: Seven 2 Zero 9 Seven 5 Six 7 Three 2
My 1987 Cossie has to go to so I can get my 911 painted.
Recent maintenance within the past 6 months.
Plugs
Wires
K&N Filter
Distributor
Cap and Rotor
Coil
Battery
Slave Cylinder
Master Cylinder
Brake Flush
Hazard Switch
Central Locking Unit installed with key fob
Completely took apart the MAF and cleaned as well as tuned the mechanical fuel injection. (This was quite the pain in the *** but it runs very well now.)
5/26/16 - Water Pump and drive belt.
5/26/16 - NEW SLS accumulators and hydraulic fluid flush.
6/7/16 - Mounted Summer Tires and new alignment by Mercedes Specialist.
6/7/16 - Brand new catalytic converter. Had a little rumble on the old one.
Exterior - 7-10 - All body cladding present only missing front tow hook cover.
Interior - 7-10 - No missing or cracked wood. Seats have no rips or tears and they all work.
(This is all rated on the fact that it's almost 30 years old. The paint has blemishes and a couple dings here and there. Pretty typical for a car with 160k miles but feels like it definitely has less.)
Engine runs strong and the oil is religiously changed every 3k miles. It does eat about a quart of oil every 3 months as well.
All the windows work and the sunroof even works flawlessly every time. All of the gauges work event the Lap Timer works and has no broken pixels. I installed a bluetooth and usb stereo.
Has Borbet Type FS 17in wheels with winter studded tires and a set of summer Khumo's and a DTM style exhaust.
I still have a bunch of parts that I will be planning on installing before it sells.
New brakes front and rear as well as a new e-brake cable and shoes.
New heater fan
The AC does not work but it never bothered me.
$8,000 obo
