190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Low idle problem
Old Jun 4, 2017 | 01:20 PM
Eganmitc's Avatar
1985 190e
Low idle problem
I have a 1985 190e 2.3 8v with a low idle (500rpms) and sometimes it will stutter and die. I have little knowledge of how these engines work but I tried tinkering with it and this is what I found. The hose I took a picture of impacts the problem. I tried different combinations of unplugging connections and found out that the issue happens when hose #1 is connected. In the picture whenever the number 1 hose is connected it idles at 500rpms. If you take it off, it idles normally (900rpms). I tried cleaning the hose but it changed nothing. What else should I try?
Attached Thumbnails Low idle problem-img_0278.jpg   Low idle problem-img_0279.jpg
Old Jun 16, 2017 | 11:07 PM
junkyarddawg's Avatar
1995 E420, 1998 E300TD, 2002 CL230K 6spd, 2002 CL230K auto, 2002 CL280T VR6 Project, 2001 A6 2.7T
I think there is a small calibrated PCV orfice hole in the white plastic connector that becomes clogged by carbon, try to clear the small hole out with a thin wire like a paper clip. Be careful cause those hose may break easy.
Old Jun 29, 2017 | 04:09 PM
Eganmitc's Avatar
1985 190e
Found the solution. Near the back right of the engine, there is an idle adjustment. You adjust how much air the engine needs at idle by rotating the black circular plastic piece with notches in it. Hope that helps!
Attached Thumbnails Low idle problem-1a95d3ec-.jpg   Low idle problem-2ebe7c50-.jpg   Low idle problem-b53d271e-.jpg
