190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Engine hard start
Old Feb 27, 2019 | 02:30 AM
terencemuchemwa's Avatar
190D
Engine hard start
I have a 190d, m601 engine 4 cylinder. My car has no fan shroud and typically goes to slightly over 80 degrees in congested roads. If i turn it off at that temperature it makes a hard start and sometimes wont start. It only starts after a while and has cooled. History: once cracked sump, crankshaft was reworked, bearing replaced. Head gasket was also replaced after removing head for a routine inspection. Any ideas on what would be the root cause with the hard start problem.
