A/C and Turn Signals problem
in the last 2 days, I've had this problem where suddenly both my turn signals and A/C turn off at the same time. It turns off the blower motor and it even turns off the compressor because I also lose cold air while the car is moving. I seriously don't know what is going on with the car now. Playing with the outside A/C fuse and fuse 1 don't always temporarily fix the problem even though the A/C fuse gives an audible click from my finger grounding the connection.
Also, if I drive the car without turn signals and A/C, eventually they turn back on, signaled by the buzzer from the car. Same as when you first insert the key and turn.
And I got this thing where stepping on the brake pedal fluctuates the fuel tank level. The stupid digital temp display on the dash also reads incorrect temperatures :/
