Brake rebuild
Brake rebuild
190E 2.3 1991
Recently rebuilt the front end and put shocks on the rear. When I took the car in for a front end alignment, they mentioned that something was holding the car back.
I decided to completely replace the brakes. Rotors hoses calipers discs
Now I’m having a time bleeding the brakes. Master cylinder was replaced approximately 18 months ago
Has anyone had a problem with the abs system. I can’t even get fluid through new hoses. Any suggestions..
Cool car. This past winter I replaced the heater core. Exterior and interior in great shape. Want to keep the car on the road. Thanks
I would suggest you purchase a Haynes manual to help you. You can order them online and they're reasonably priced. I'm at a loss for why the brake fluid isn't draining through the hoses. You might also check your emergency brake. You might also check in with the MB Classic Center. They're very knowledgeable about the 190E and very helpful. That's where I go when my 190E stumps me.
