190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Engine Swap
Old May 24, 2022 | 12:24 PM
jdcsaun's Avatar
190e
Engine Swap
I have a 89 190e I wanna swap the engine out because I want a manual transmission because I plan to drift it, but idk any Benz motors that come with a manual besides the 190e with the dogleg, and I can't find any so the last resort is to swap the engine and trans out but idk what to put in it. I was thinking k series but apparently there's a lot more that goes into that. I know there's some fabrication you have to do with the firewall on some swaps so I'd like to stay away from all that.
Old May 24, 2022 | 06:19 PM
Pirublues's Avatar
'67 250se - '80 450sel 6.9 - '93 190e Sportline
Mercedes m272 v6 came with a manual. As well as the 4cyl of that timeframe.
Old May 25, 2022 | 01:09 PM
190Efan's Avatar
1991 190E 2.3
I don't think the 190E is well suited to be used for drifting. I think you're better off buying a car that's better suited for drifting and that already has the manual transmission you want.
Old Jun 21, 2022 | 09:49 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
https://www.google.com/search?q=190e...hrome&ie=UTF-8
Old Jun 21, 2022 | 12:04 PM
190Efan's Avatar
1991 190E 2.3
It'll be far more costly to create a car that can successfully drift than I think you realize especially since you're starting with a car that was not intended to be a hot rod. There are other cars out there that are already much better suited and would be less costly for you to turn into a drifter like a CRX, Celica GT, Z, etc.
Old Jun 21, 2022 | 01:25 PM
insame1's Avatar
all of those cost way more to start with though. if you can fab an angle kit it wont be that much
Old Jun 22, 2022 | 11:52 AM
190Efan's Avatar
1991 190E 2.3
I think you're in for a surprise. You'll likely wind up spending the cost of a more suitable vehicle and more. There are no shortcuts.
Old Oct 20, 2022 | 06:09 AM
Sully ZA's Avatar
Mercedes W163 ML 350, Mercedes W201 190E
Hi guys … I trust everyone is well
i am considering fitting a m104 2.8 engine from the w202 c280 in my 190e and was wondering if I could use my stock 5spd manual gearbox that is currently in the car and the stock engine mounts?
Engine will remain stock only adding E46 m3 throttles which I already own!
I know I need to use an aftermarket ecu which I will be acquiring later on (Fuel Tech)
If not can anyone please advise which Manual Transmission would work with the m104 and which engine mounts I need to acquire
thanks
Old Oct 21, 2022 | 12:20 PM
dolucasi's Avatar
190E 2.6L 1989, 190E 2.6L 1988, BMW 535dXdrive 2014, BMW 428i 2015
This probably needs a separate post as it is a different subject matter, I would suggest starting your own post. That being said we do not know if you have the M103 or M102 engine in your 190E. If M103, I suspect it will be a bolt on. If 102, it is a bit more involved (from what I have read for years)
