Wat's this part?
Find out where the ambient air comes in and make sure that is not blocked. You can also test it now that you are there. I believe it receive a 5V input from the ECU and that voltage get's divided based on air pressure (altitude) Sort of similar to the AFM pot on the throttle body. There must be a spec somewhere for sea level voltage coming out of the altimeter.
But overall, I see no harm in hot glueing it in 4 corners. Since it comes off I would appreciate if you can take a closeup picture of the inside and post it here. Curious to know what's in there.
- Cheers!
