190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Driverside Vacum Lock gone. help!
Old Dec 2, 2004 | 07:47 PM
DongDong's Avatar
hello, today i noticed that i cant unlock/lock the car from the driver side door any more. usually, there would be pressure that pushes up against the key but this time there isn't. does anyone know whats the problem with it? i have to go to the trunk to open/close the door. thanks!
Old Dec 2, 2004 | 08:20 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
Could be a failed door lock actuator or a loose vaccum line to the accuator. Either way, you'll need to remove the inside door panel (just takes a screwdriver and knowing what to pop up) to have a look.
Old Dec 3, 2004 | 06:57 PM
DongDong's Avatar
do you know which screws i take off?
Old Dec 3, 2004 | 07:13 PM
MTI's Avatar
MTI
Very nice "write up" with pictures here
Old Oct 15, 2008 | 09:22 PM
ed-E300TD's Avatar
From: Washington DC / No. Virginia; and Cape Cod, MA
'71 280SE
190E Driver's Door Lock
Thread's gone.
Could you re-post?
Old Oct 16, 2008 | 08:14 PM
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
unscrew screw in outside part of door where it locks with the plastic c around it. then pop off the plastic cover around the top of the handle and unscrew the bolt (8mm i think) then you push the part with the handle towards the outside of the door(undoes handle) and pop off the seat buttons and take off the surrounding and unscrew the screws holding that in place(2 on opposite corners). then you just pull the panel up. you just do the opposite to put it back on.
