190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Checking Auto trans fluid
Old Oct 6, 2025 | 02:02 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Just change the filter and fluid on the auto trans on my 190 E 2.3. I measured the exact amount I drained and put that amount back in. I have been checking the fluid but its extremely hard to read the dip stick. Fluid seems to be smeared and not like on oil stick. I check it with engine on and in Park. Seems when I pull the stick out it smears or erases the fluid on the stick. Suggestions
Old Oct 7, 2025 | 11:49 AM
190Efan's Avatar
1991 190E 2.3
You should fill your transmission with the amount noted in the owner's manual because a previous owner might've put in the wrong amount. The lines on the transmission dipstick are indentations. You always want to make surethat your car is fully warmed up before you check the transmission fluid level.
