190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
car pulling to the right
Old Feb 28, 2005 | 09:52 PM
DongDong's Avatar
hello, i have a 190e 2.6. when i drive the car, it tends to pull to the right. i got an alignment done and it still does that. any idea whats up? thanks.
Old Mar 1, 2005 | 02:18 AM
SVantley's Avatar
1984 190E 2.3
My car started to pull to the right ( )after I put my 17's on my car.
Old Mar 3, 2005 | 08:26 PM
MaciekPL87's Avatar
'92 190E 2.6
My car also pulls to the right and seems unstable and needs to be corrected going straight at fast speeds. Other than the balljoints and struts that I knew needed changing, he found that the control arm bushings are badly worn, and the idle control arm bushing. In 13 years of salty weather the rubber disintegrates quick. Hope that helps and check those items.
Maciej
92 190E 2.6
Old Mar 4, 2005 | 05:35 PM
vas2vas's Avatar
87 190E 2.6/1995 M3
mine pulls to the left.... can't find anything wrong with it tough, and as long as I keep the wheel a little turned it does straight... starting to think that someone in the past took the wheel off and didn't put it back straight...
Old Mar 5, 2005 | 08:14 PM
Gullwing's Avatar
1987 190E 2.3
Could be a tire pull, try crossing the front two tires.
