*Product Release* ALPHA Performance Billet A45 AMG Intake
The factory intake was designed conservatively in an effort to muffle intake and turbo sound. Unfortunately, in order to do so, inside diameter of the inlet is reduced to a suffocating 2.6 inches! The Alpha 45 Series AMG Performance Intake System widens the inlet to 4 inches using a CNC billet aluminum adapter flange while offering a pleasant, more aggressive intake sound that you’ll actually appreciate.
Our Alpha 4″ filter inlet compared to the stock 2.6″ filter inlet
Clear anodized CNC billet aluminum intake inlet
Synthetic high-flow dry media filter outperforms comparable leading brand with no oiling required.
Completely washable and extremely durable, our synthetic high-flow dry media filter was designed to last the lifetime of your 45 Series AMG. It also requires no oiling and provides greater flow efficiency and filtration than the comparable leading brand. By simply installing this Alpha air intake upgrade, you can expect a 20+ horsepower increase with no additional mods necessary!
20+ horsepower gains with the Alpha Performance Intake alone
Exclusive Benefits
20+HP increase in just 15 minutes
Uses factory ducting for cooler air charge and maximum power
Reduces turbo lag
Smooth transition for best airflow
High-flow, low maintenance dry media filter
No computer tuning needed
Applications
C117 2014+ Mercedes-Benz CLA45 AMG
X156 2014+ Mercedes-Benz GLA45 AMG
W176 2013+ Mercedes-Benz A45 AMG
$299.95 http://www.amsperfor...ake-system.html
