A45, A35 AMG (W176, W177) 2013 to present. Two generations
Filter and cooler recommendations?
Old Sep 7, 2015 | 08:52 AM
ScottA45's Avatar
A45
Just wondering if anyone has any recommendations on which filter and cooler to go for?
Would like the filter to have an inlet or 4/4.5 inches
Old Sep 7, 2015 | 09:56 AM
Team@Rebellion's Avatar
Former Vendor of MBWorld
E63 AMG
I'm Slightly biased but I can recommend our intake kit.
Its extremely easy to fit, the adapter is made from high grade stainless steel and our filter is a dry foam filter that is washable so no need to replace etc. UK Made too
http://store.rebellionautomotive.co....intake-system/
As for coolers the car runs a charge cooler system so is very efficient, Depending on where you want to go with power you can upgrade to a front mount cooler that gives additional coolant in the system and has additional surface area.
Additionally we have gearbox and oil cooler system depending on how how you are running etc.
Old Sep 7, 2015 | 10:21 AM
ScottA45's Avatar
A45
I'm basically looking to get the most hp I can out of it over time, so I would eventually be willing to switch as much as possible to get the best gains.
Had a look at your website there and I like the look of the products, however the stage 3 remap doesn't have every product you stock installed, have you got any figures with every product installed? Basically what's the hp and torque when it's fully modded?
Old Sep 9, 2015 | 05:06 AM
E63 AMG
Hi Scott,
Our stage 3 package contains:
3.5 Inch Downpipe
3 Inch Midpipe
4 Inch Intake Kit
Front Mount Intake Cooler
TTE460-R Turbo Charger (exchange with your turbo)
Your ECU Returned with Stage 3 Flash installed
There are additional items we can add that are not standard package items but will add performance in different ways, so things like:
Full Valvetronic exhaust system
Water Methanol Kit
Nitrous Kit
Gearbox Cooler
Lightweight Braking systems
Carbon Items
So all just depends how you want to go about building your car
Old Sep 11, 2015 | 08:51 AM
steponthegas's Avatar
2006 M-Class ML350
I highly recommend that you get the K&N Cold Air Intake for your ride.
Old Sep 14, 2015 | 11:12 PM
Stanley59's Avatar
GLA45 AMG
Rebellion or Willall Racing for the cooler and intake or the AMS are both excellent choices.
Actually, K & N only has a filter replacement for the GLA or A45 AMG with a 2.5 inch intake opening, so it's not much better than the OEM part.
