A45, A35 AMG (W176, W177) 2013 to present. Two generations
A45 fuelling problems on full tank
Old Sep 2, 2019 | 05:23 AM
Lsc297's Avatar
A45 AMG s2
Hi, I just bought a series 2, 2016 model A45. I just filled the tank, and on the way home, it started cutting out, implying fuelling problems. I looked on Honest John's website, and it seems a similar problem occurred in Germany, due to the fuel tank lining breaking up & blocking the fuel lines. Has anyone else had this problem?
The car is under a 2 yr AMG warranty- I bought it from MB. Any suggestions?
thanks,leo
Old Nov 4, 2019 | 03:00 AM
Bear19's Avatar
A45
Tank empty early
Yes, had same problem. Used a air hose on fuel tank to clear blockage.
Old Jul 9, 2020 | 04:48 PM
ChiefTed's Avatar
AMG A45
Mate, I have the same issue. When refuelling it cuts out repeatedly. I get dispense maybe 2-3 litres then it cuts out. Have tried holding the nozzle different ways, feathering the fuel...you name it. Took it to the MB dealer and they said a "Fuel Filter Vent Valve in tank failed".... QUOTE: $3238.80 fitted. A New fuel tank! Rubbish...
Old Jul 9, 2020 | 05:09 PM
Bear19's Avatar
A45
Fixed
You need to a compressor to blow out the blockage it happens when you run the fuel to low the waste get stuck with nowhere to go. Just give it a blast of air and save you $3238.80 problem cost you $20 to use the compression hoes.
Old Jul 10, 2020 | 12:29 AM
ChiefTed's Avatar
AMG A45
Cheers..I'll look into that option. Though isn't this valve inside the fuel tank itself? (2014 model)
Old Aug 20, 2020 | 05:35 PM
Ian Pitt's Avatar
2015 A45 AMG
Hey Bear. Can you let me know where you apply the compressed air. Is it at the fuel filler or somewhere else.
Having this issue with a 2015.
Cheers
