Questions about a Distronic retrofit and front grille emblem
I have two questions about this:
- It looks like the emblem doesn't have the silver ring that goes around it. Is this a separate part that I can get somewhere?
- Looking at the back of the emblem (picture below), I see that it has a connector that I believe is for defrosting to make sure that ice doesn't build up and the radar signal can get through in cold weather. I don't see a connector for this on the wire harness behind my bumper like I did with the radar sensor. Am I out of luck there or can I still connect the defroster on the emblem somehow?
Thanks in advance.
1. No, you can't get it as a separate part.
2. It doesn't look like this is possible. The car apparently doesn't support the defroster, but the cruise control should still work OK without it. If I find any info to the contrary, I'll update this post.
