A45, A35 AMG (W176, W177) 2013 to present. Two generations
2014 A45 P0339 Crankshaft position sensor error code
Old Apr 25, 2025 | 06:39 AM
Mercedes_45's Avatar
Hello eveyone,
My car has become nearly undriveable due to recurring P033900 & P033904 crankshaft sensor faults. Symptoms include jerking, limp mode (~3K RPM limit), engine shutdown while driving, and CEL.
Steps Taken:
  • Replaced sensor with OEM part
  • Checked wiring/connector – no visible issues
  • Checked flywheel no issue
  • Sensor installed properly, codes still return
  • The issue persists after replacement even getting worse more jerking with engine shutdown.
Anyone else faced this and found a solid fix? Appreciate any advice.
