pre-safe function currently limited
After the incident, the message "PRE-SFE function currently limited" appeared on the dashboard. I took the car to a specialist, and they removed the front bumper to inspect the sensor. the sensor itself was intact and showed no physical damage.
Because the warning message remained, they performed a system reset, the message disappeared after the reset; however the Pre-Safe function is no longer working.
Previously the system alert the driver when there was an obstacle in front of the vehicle, and in case neglect by the driver, it brakes by itself and tightens the seatbelt.
Did someone had this same issue? Thank you in advance
Garin
for your assistance.
