GT/C192/R192: Upgrading a GT 55 to a GT 63
The 55 has better lower end torque which is why it’s able to jump ahead at the start of both races. Thats how Mercedes makes thier cars. On a street the 55 is actually a bit more torquey and quicker than the 63 especially with a tune.
you don’t notice the difference unless going too a track like such. Also considering how close the roll race was I wouldn’t say it “wasn’t close”
I read on another thread here from another member that the way AMG builds thier cars are so that the 63 can really thrive on open roads at 150+kmph range. Below that on shorter pulls and regular city driving the 55 and lower models actually feel quicker and more responsive due to them being built for that.
if you put the time and money into it you can most certainly get the 55 to well above 63 levels although I wouldn’t recommend anything past stage 1 for avoiding warranty issues. But a stage 1 on the 55 is more than enough if you’re not going to track it.
800-900 is absurdly fast, any goal of what output you’re trying to reach or just shooting for the stars
Number 2 an article and press release linked below from MBusas website confirms the vast similarities between the 55 and 63 engines including BOTH HAVING the twin scroll turbos, his experience as stated stems from the M177 variant in the c63 model. Remind you this is a GT were talking about not a c-class, completely different worlds here.. So the idea that the GT55 uses or may use single scroll turbos like the old C63 is flat out wrong. That reference point doesn’t apply, this is a flagship top tier AMG GT not a c-class with older hardware..
The only thing id say i cant argue is his claim about a simple piggyback tune not turning the 55 into a 63 which is somewhat correct, but it gets it fairly close for just a piggyback. Put a real ecu tune and some minor cooling upgrades and youre there. Both engines share the same mechanical dna and makeup. Its the same engine same platform tuned differently with minor upgrades to allow for sustained abuse and higher tolerance as implied by Mercedes benz themselves. I still stand firmly by my 90% same to 10% different stance and the facts from mercedes benz themselves undeniably backs it up.
The new Mercedes-AMG GT Coupe
I still stand by my thoughts that the 63 is extremely poorly priced but there are deals to be had no doubt.
As shown in the video above, a properly tuned 55 making 579hp is still understandably reeled in by a stock 63 likely putting down as you said earlier closer to 630hp. That doesn’t contradict the argument, it supports it. The 55 can absolutely match or exceed stock 63 numbers with a solid tune. That’s the whole debate whether the $30K+ premium for a 63 is worth it, given how closely related they are mechanically.
Once they start producing actual ECU tunes for the 55 it will no doubt hit 63 power with a simple tune.
