Steep driveways
Steep driveways
I live in Texas where many people drive trucks. There are many steep driveways.
I have been avoiding steep driveways and when I cannot avoid them, I'm going up and down at an angle. So far I don't think I've scraped anything.
Who else has to deal with many steep driveways in their area, and how has the car managed so far?
I haven't had an issue most places because this car has better clearance than my GT3 or Z06 did. At stock ride height, this thing has better clearance than any car I've owned in the last decade plus. I'd love to lower it and put different wheels on it but it's so nice not scraping everywhere.
I did manage to curb the **** out of my carbon fiber front splitter thingy going to a new restaurant a couple of weeks ago. I didn't want to be "that guy" and refuse to go eat somewhere because of my car but in hindsight, I wish I would have.
My driveway is steep enough to give an F80 M3 difficulties, so my fingers are crossed for the GT. Does anyone have any comparative experience?
Also, a question - just because you can go up, does that necessarily mean you can come back down?
Reason I have some doubt is that an angled approach, while deadening the gradient, does cross up the ride height, as the car levels. Not so bad for the rear, but front is way lower.
Thoughts?
Thoughts?
I agree with Gordon here. Torn between lowering and the dreaded scrape. It's nice not to think about. I had a 2014 427 vette convertible with a carbon fiber lip. Actually cracked it on a regular road on a slight dip that should never have happened. 1400$ BS.
If you look underneath front clip, there is a relative wide 1.5-2" strip of plastic that I've brushed lightly a couple of times on quick drops off inclined driveways, but that's it.
I took the plunge and lowered the car to max drop on the KW HAS kit. Luckily the roads aren't too bad here in Orange County but once outside of Irvine, it gets pretty rough. I typically take the time to scout different entrances/exits if I think one is too risky.
So far, my front lip is clean as a whistle.
The following 2 users liked this post by MercAMGgts2016:
sonystyle02 (01-18-2017),
traumadoc (03-04-2020)
Administrator
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
Im lowered too maxed out on the KW's and to this date, no issues with scraping. But I do angle in and out by habit in a lot of situations. Whats nice to know is the part that could get damaged is easily replaced and not expensive:
The following 2 users liked this post by Vic55:
bruceeboy (03-04-2020),
Administrator
I too run Sport now vs S+.
sonystyle02 (01-19-2017)
Do most people, not lowered, feel that their cars nose can clear a standard parking block?
This is is the first car i have had in a while without a 360 overhead camera. Those parking sensor lights in the instrument cluster aren't very reliable in any Mercedes I've driven. So far, when I've ****ed up I seem to just barely clear the parking block, but probably scraping it a little.
On GT it is just a 2" plastic strip but I'm still careful.
MercAMGgts2016 (03-03-2020)
2022 AMG SL63
In fact my front air dam is now loose in the middle and slightly hanging down. The air dam is held in place by a series of rivets designed to break loose in case the dam gets jammed up badly. If it breaks loose then the front end pieces don't come loose and get damaged. My SA told me in that sense it is sacrificial in its installation. I would love to be able to get mine up in the air and put a couple of small sheet metal screws in it to get it back up. The SA said that the way it is designed they can't just put a new rivet up there.
I can't clear much of anything and have to be careful. I never get close to a parking block if I can help it - even if I have to the leave the *** end out a bit. I try to back into parking spots if possible.
Before you fire back at me, it's the direction that ALL manufactures are going.
The rear is low too.. if you back into a spot, you can only reverse so much before the parking block comes into contact with the underneath of your AMG GT. Look underneath, its a strange design, but the rear is lower than the front
2010 Irridium Silver MB C63 AMG Sedan
I feel your guys pain. The GTR has the front splitter and the rear CF exhaust cover. Not high enough to clear many parking structures. The front has this rounded rubber airdam cover underneath. I’ve rubbed this once but was able to polish out the scuff. My driveway is inclined up pretty steep and it sucks. Each time I roll down I have to lay down large sheets and planks of wood to minimize the pitch. It’s such an ordeal driving it. After I sloooooooowly pull in I have to put away half a tree of wooden pieces neatly away...and don’t even talk about parallel parking. That’s like entering a mine field...
