Sponsored by: Innova
Memory on Radio resets after i turn off car???
Old Mar 3, 2005 | 03:32 PM
BKLYN_CLK's Avatar
I installed a alpine radio into my clk and everytime i turn the car off the radio's memory resets?? Does anybody know which wire is the memory coming from the wiring harness. or is there another way to fix this??? thanx
Old Mar 3, 2005 | 06:54 PM
Barada's Avatar
1979 911SC, 2001 E55, 1999 CLK430, 1993 190E 2.6
I may be mistaken, but if you used the VW harness, the memory and Ignition are swapped for VW. Swap those and that should cure. I would check it first.
Old Mar 7, 2005 | 05:53 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
You are right here... the VW harness although it is the same plugs... wires do not match up... connect your yellow(constant) from the VW harness to the Red of the alpine harness and the red(ignition) from the VW to the Yellow of the Alpine harness<-- Easy fix... or if you want wire colors to match for possible troubleshooting down the road use pull the yellow and red wires out of the VW harness swap them and plug them back in!!!
Old Sep 6, 2005 | 11:01 AM
d2Benz's Avatar
2017 GLE350 4MATIC, 2009 ML350 4matic, 2005 4maticWAGON (sold), A Pre-facelift W210(sold)
Is this only true for Alpine units?
I'm about to install a Kenwood unit, do I need to swap the red and yellow in this too?
cheers!
Old Sep 7, 2005 | 07:25 PM
d2Benz's Avatar
I'm about to answer my own question.... yes, its true to all head units...not limited to Alpines only.
Well, I changed my mind about the kenwood unit and installed an Alpine Unit.
Much better sound than the factory radio...the only replacement is just he HU.
