Sponsored by: Innova
siemens s65, s66, cx65, cx70
Old Mar 14, 2005 | 11:51 PM
Ted Baldwin's Avatar
300ce
..............i am a bit confused.Does the UHi kit provided by steve support s65, s66 or cx65? DO they all use the same cradle? The cradle has CX65 printed on it, but I remember discussing with Dean that I wanted to get an S65 phone. Do I have the wrong cradle? What is th CX70? does it use the same cradle as the Cx65? Finally, does the S66 phone work with the UHI kit? Thanks,
Ted
Old Mar 15, 2005 | 03:07 AM
SUNILP's Avatar
2015 E250D
s66 does not work with UHI
Old Mar 15, 2005 | 07:52 AM
Teck's Avatar
C 320 CDI 4M W204 / C43 AMG (W202) / C 220 CDI T (S203) / ZX-10R Ninja
I got the S65 and it works in our cars!
Old Mar 15, 2005 | 08:35 PM
300ce
.............can you look at your s65 cradle. Does it say CX65 or does it say S65. Essentially are the S65 and CX65 cradles the same? Thanks.
Ted
Old Mar 15, 2005 | 11:02 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Ted
The CX65 cradle is the only cradle there is. It supports the CX65, the CX65V, and the CXT65. The S65 will work in this cradle but it is "noch nicht freigegeben" (not approved), probably because of some problems with it. I believe the CX70 should work in this cradle too. The S66 seems to have problems as well with this cradle, but a fix is in the works for this.
-s-
Old Mar 16, 2005 | 03:19 PM
300ce
Thanks.
Ted
