02 C230 Coupe "Audio Tone Level" Adjustment???
Ok folks, so I searched and came up with a few things on this, but none were paticulary conclusive.
In the threads I found some that said it was only available on "Bose" models, but then I found that supposedly all C230's had "Bose" models. So I thought I should be able to adjust it from there....but I can't.
Just an aside, the owner's man. says you should access it from the AUD soft key, then press EXT and be able to adjust for Driver, Speech, or Ambience, but its not there???
SO....
1. Is the Audio Tone Level Adjustment only for "Bose" models?
2. Do all C230's actually come with "Bose" units
and
3. If so, then what is the secret to accessing the Audio Tone Level Adjustment?
Aaron
SO....
and
Aaron
