Sponsored by: Innova
CD Changer Problems 02 C230k
Old May 11, 2005 | 06:41 PM
Steve C's Avatar
I am having major issues. My changer will not function from the radio. It is stuck on TRACK 11 CD1 and will not respond. I can open the unit and remove the magazine but it will not play anything and will not allow me to change anything. Any help would be appreciated.
Old May 11, 2005 | 06:44 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Did you search for solutions that users here have tried when having CD changer problems, such as pulling the fuse to reset it? If not, you may want to try some of those remedies before shelling out $400 for a replacement.
-s-
Old May 11, 2005 | 06:54 PM
Steve C's Avatar
I've tried disconnecting the main power harness to the unit and I've also checked the fibre optic cable and that hasn't helped. If I disconnect the battery or pull the fuse for the radio will I have to get a code to reset the security feature on the radio?
Regards,
Steve
Old May 11, 2005 | 06:56 PM
Steve C's Avatar
On a further note.... when I disconnected the CD Changer I tried powering up the radio and it still thinks that the changer is plugged in..... it stays on that same screen. The only thing I can do from the CD screen is adjust the audio paramaters.
Old May 11, 2005 | 07:12 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
I do believe there was a thread that discussed issues with disconnecting the CD changer and then forgetting to close the fiber loop and the results thereof. STFF
