Sponsored by: Innova
Hard Wired My Passport
Old May 12, 2005 | 04:07 PM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
I just hard wired my passport radar detector. The only problem is it doesn't turn off with when i turn off my engine. I have to manually turn it off. I hard wired it VIA fuse box on the driver side. Does anyone have any suggestion on which fuse to use? They seem to be all live.
Old May 12, 2005 | 04:30 PM
Jput's Avatar
CLK430, CLK500, SL500
I would use the same one as your radio or another fuse that is turned on and off, ignition should work as well.
Old May 12, 2005 | 05:21 PM
tomk's Avatar
2006 CLS55 AMG
If the wiring in your car is like my CLS, you will have to find a fuse in the engine compartment to find one that is switched to the key. I tried to find on on the side dash panel and they are all on all the time. Had a professional install my and he reached way up and found the wiring harness where it come thru the fireway from the engine compartment main fuse bus. Pushed a piece of HD speaker wire thru and then tap on to that. Good luck with the modern wiring/electical circuits of today.
Old May 13, 2005 | 07:40 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
christian... just swing by the store and Ill find it for you!!!
