Sponsored by: Innova
NAV System 01 S 500
Old Jul 12, 2002 | 07:28 AM
Steverock's Avatar
NAV System 01 S 500
When I set my NAV system to CURRENT LOCATION and drive in that setting the cursor goes off the sceen. In other NAV systems the map scrolls so the cursor is always showing you the current location.
Does anyone know if this is normal for this system or is this a bug.
Steve
Old Jul 12, 2002 | 01:39 PM
MBfiend's Avatar
2008 S550 4Matic P3, Pano, Distronic, Sport
Mine does the same thing on my '00. Guess it's just part of the system.
My Lexus NAV BLOWS away the MB system and doesn't do it. It just merrily follows along with me.
Old Jul 12, 2002 | 07:02 PM
awiner's Avatar
2003 CL55 AMG
Re: NAV System 01 S 500
Steve
Not normal. The map data should scroll as long as the map you have inserted is in the correct geographical region as you.
Old Jul 14, 2002 | 02:13 AM
SFC320's Avatar
2002 C320
RTFM
If you want the map to scroll while the location of your car stays in the center of your map....you need to hit the MAP button.
If you select current location, the system allows you to move a crosshair (using the number keys) to where you want to go. When it is positioned correcty, select the location and it will calculate the directions. Personally, I always get directions based on Address or via Points of Interest.
This is the way it works in my C.... I can't imagine that your Command doesn't have this functionality as well.
Old Jul 16, 2002 | 02:00 PM
Steverock's Avatar
There's no map button on the S 500. According to my dealer the lack of scroll on Current Location is a system bug. Very annoying problem for such a costly car.
