Anybody knows?Aux1 and AUX2 in W211 COMAND
2004 SL 350 & E class 200K avantgarde
I will retrofit COMAND and TV tuner my W211 (05) by Mbenznl soon.
I read comand manual said,
---Two external video sources(aux1 and aux2*) with sound and picture
signals can be connected to the TV receiver
---What 's AUX2*? Can I have it after Comand retrofit
I also install ipod kit with comand( so it is AUX 1?), so I wonder if I can use AUX2 input for my other video source throgh connectors---eg: Playstation or ipod movie(?)
---Can I need install connectors for AUX2 input wiring in glove box or arm rest?
Anybody knows?
Thanks in advance...
Anybody knows?
W203 slightly modified
Anybody knows?
Anybody knows?
This is what the AUX 1 and AUX 2 looks like.
Notice on the left side that the AUX inputs are coded normally. So if you attach a cable long enough then certainly you can place the other end of that cable somewhere inside the car. I dont know how you will go with earth loop noise as I understand for long runs you will need to install a noise suppressor.
It would be easier to run IR extenders into the trunk area and leave the gear connected on a shorter cable.
I am confident that Steve can suggest some of the possible solutions.
To Mbenznl
Thanks for your kind explanation, Benzmodz.
Steve, I need your help for Aux2 cable install...
And about seats...Contact me please
