Sponsored by: Innova
Saving AUX audio settings on Comand?
Old Nov 18, 2005 | 06:02 PM
Blake P's Avatar
'09 A4 S Line
I use the AUX on my Comand all the time for listening to my iPod, but it annoys me that every time I start the car, I have to re-adjust the audio settings for bass and treble (though the fader setting is saved) because they go back to "0" by default. I'm not sure if this is normal, but only my cd and AM/FM audio settings are saved at whatever levels I set them, while AUX audio settings for bass and treble are reset to "0" every time I turn off the car. Anone else have this problem or am I alone here?
Old Nov 19, 2005 | 12:29 PM
Wolfman's Avatar
Super Moderator
Same on our SL. AUX primary sound settings can't be saved. Just the sound options.
My fix was easy and works better than the simply treble/bass adjustments; I ran thorugh all the iPod equalizer (EQ) settings to see which sounded best in the car. A bit more hassle, but easily better sounding.
Wolfman
Old Nov 19, 2005 | 01:13 PM
Blake P's Avatar
'09 A4 S Line
Wolfman
Yeah, I thought about that too but was hoping there was a better way
Old Nov 19, 2005 | 01:18 PM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
Blake, I just tried on mine and the settings stay. I changed them and then shut the car off and removed the key and let it sit for a couple of minutes and then restarted and checked the settings and all is the same. Do you have a US or Euro COMAND? I have Euro, so maybe something with that.
Old Nov 19, 2005 | 01:32 PM
Blake P's Avatar
'09 A4 S Line
I have a US Comand. You're sure that you changed the AUX sound settings, not the regular sound settings for CD and AM/FM radio? I know those settings stay saved in my car.
Old Nov 19, 2005 | 01:37 PM
JohnCL's Avatar
Yep, sure did. I had my satellite radio on and I changed them twice. SYS to AUX to SOUND. Stayed for me just fine.
Old Nov 19, 2005 | 01:53 PM
Blake P's Avatar
'09 A4 S Line
Dang, must be an added perk to having the Euro Comand. Have you had any problems playing DVD through your Comand screen using the A/V adapter?
Old Nov 19, 2005 | 02:10 PM
JohnCL's Avatar
No problems at all, it works perfectly. Are you having issues with yours?
Old Nov 19, 2005 | 02:13 PM
Blake P's Avatar
'09 A4 S Line
I noticed that it's been skipping alot lately, but doesn't seem to be caused by bumpy surfaces or anything related to the DVD player. It has happened with burned DVD's only, so I'm going to test it today with authentic DVD's to see if that makes a difference.
Old Nov 22, 2005 | 10:03 PM
JAM's Avatar
JAM
SL600
I can confirm that the Euro Comand DOES save AUX input audio settings, yet the U.S. Comand DOES NOT.
Old Nov 22, 2005 | 11:18 PM
Jayhawk's Avatar
S500/W220/2000
Me too: I do not have an AUX or any way of connceting an iPod or anything else in my car. Wish I did! I do have SYS...
Old Nov 23, 2005 | 07:27 AM
mikefl52's Avatar
2002 C230K Coupe & 2005 C230 SS
On the C class US COMAND, the aux settings are saved.
Old Nov 23, 2005 | 09:37 AM
JAM's Avatar
JAM
SL600
Interesting. My information is for the E-Class (W210).
Old Nov 26, 2005 | 11:02 PM
Cocca's Avatar
2019 Land Rover Discovery 2018 BMW 540ix 2013 Land Rover LR4 2007 Porsche Carrera 4S Cabriolet
XM Commander
I just got XM direct wired thru the AUX. Bass/Treble, etc RESETS EVERY TIME CAR IS SHUT DOWN. Slightly more than annoying.
Is there anything that can be done? If not, can anyone at least give me justification for this quirk. Ze Chermans always have a good reason for everything associated w/the M-B's I wonder what the reason for the reset is.
H E L P ! ! !
Old Nov 27, 2005 | 08:44 PM
JAM's Avatar
JAM
SL600
It really does not make any sense. Since the euro unit is capable of saving these settings, I am sure there is some way to get this to work at the firmware level/BIOS of the unit, but I have no idea how to access that. I don't even think that StarDiag would have that option to set.
