Question About New E Class Color Matched Small Sirius Antenna
1. Is the new smaller color matched Sirius antenna drill mounted also or is it "Peel and Stick".
2. If I use this new antenna, can I utilize the same hole or do I have to make more holes? Outside of possible paint fade around the old larger antenna, is there any reason I shouldn't change it?
3. Why does this new antenna require the use of a "splitter" where the old on didn not?
4. I've been told its "plug & play", will the trunk still be watertight with the smaller antenna?
I could not tell how they were mounted as I wasn't able to get out and go look (we were sitting at a stop light). They were mounted at various places across the decklid. Probably doing some kind of Sirius testing. I didn't notice anything else special about this car.
Oh.. a M plate car is a test vehicle here in Michigan with a manufactuers plate on it. Normally see tons of Ford, GM or Chryslers.. not too many MB's though.
It is still drilled.
If you have color fade, eventually the area around the antenna will eventually fade. I would hope that modern paints are much less prone to fading.
I have no problems with water tightness.
For the details I would talk to your dealership, but maybe do it yourself since they will probably charge a lot for the labor.
