Sponsored by: Innova
navigation locations not showing in area
Old Dec 10, 2005 | 10:11 AM
chuey12's Avatar
hi
i just got my ml500 last week and i love it EXCEPT for the navigation.
chances are im doing something wrong but im not smart enough to know what
when i type walmart (or home depot, target, or any store) as a POI it will find the store in California, seatle, texas......BUT I LIVE IN CAROLINA!!
is there something i need to do to the settings or something so it will show POI's in my area???
BTW.. great forum
thanks
chuey12
Old Dec 10, 2005 | 11:33 AM
morph860's Avatar
2013 C300 Sport 4Matic
do you have the right cd in?
Old Dec 10, 2005 | 01:37 PM
chuey12's Avatar
its actually the dvd version so i think its just 1 dvd....
Old Dec 10, 2005 | 02:40 PM
AMG_Fred's Avatar
Mercedes-Benz w124
I doubt 1 dvd is enough for all of usa. Check your specific forum and they can probably tell you. You will probably have to buy one from the dealer or on ebay.
Old Dec 10, 2005 | 05:36 PM
weinschela's Avatar
'14 E350 wagon; BMW G12 (2020) G01 (2019)
Well, you may doubt it but the DVD systems do indeed cover the entire US. I think you put in the POI and select "around current location" and that should do it.
Old Dec 10, 2005 | 05:54 PM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
Not sure about the Command unit. In my Alpine system, I have to choose a area on the address or location setup. It is defaulted at CA, but I live in IN. So, when first power up, I have to change it to midwest region before getting correct information. Oh, it's DVD and it covers the whole US but with 2 DVD, one for Eastern and one for Western.
Old Dec 10, 2005 | 08:24 PM
SUNILP's Avatar
2015 E250D
There is indeed 1 dvd for the entire USA and CAnada. Check the version and make sure you have the latest version. THe POI's are not very helpful at times so I would suggest you type in a address instead.
Old Dec 11, 2005 | 11:05 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
You may have to change the default geographic region of the country for the initial search. I don't recall the exact menu for this - it is availabe through the softkeys on my '05 S500 (I think under "settings"). Your ML has a bit different system than mine - but your operator's manual should tell you how to do it.
You should not have to reset this each time once you have done it.
Old Dec 25, 2005 | 02:21 AM
SJRAMROD's Avatar
I understand that my Lincoln Navigator is an entirely different system but, it only requires 1 CD. You need to choose the geographical area that you are searching in first. Each area usually involves maybe 5 to 8 different states. After this is determined and selected, there is an option to search in "5 closest cities". In addition, I can also get icons of the POI's to appear on my map display. This way you can just select it if you are near it on the map!
Don't know if any of this helps?
Old Dec 25, 2005 | 08:50 AM
Barry45RPM's Avatar
2015 ML 350
On my '04 E Class, 1st you press Current location, then POI's, which gives you a list of types of POI's. You select the type of POI, then it gives you a list. You hilite the item on the list then press info.
