Sponsored by: Innova
Radio QUIT.......
Old Jan 7, 2006 | 12:49 PM
sped's Avatar
2008 GMC Sierra
Radio QUIT.......
Last night I was sitting in my car (CL600) listing to the radio, all of
a sudden it just quit working. I tried all the buttons and everything
worked except no sound! I drove home and shut the car off, waited a few
minutes and started the car, the radio came on full blast!!
Do I have a poltergeist in my car?? I have had a few other things
happen like this, start the car and the ABC is in-op, then I restart the car
and it works fine.
Ed
Old Jan 7, 2006 | 07:15 PM
CalifSLK's Avatar
SLK 350
Is that a Bose system? If it is, then check the amp power relay. This relay cycles everytime you start the car.
Old Jan 7, 2006 | 10:12 PM
sped's Avatar
2008 GMC Sierra
Yes it is Bose. The radio works fine now, it quit while it was playing and started working after the car was restarted. It (the relay) would check out OK if the radio is working, right?
Ed
Old Jan 8, 2006 | 03:19 AM
CalifSLK's Avatar
SLK 350
Yes, if it is working, the relay would check out ok. There are a lot of current going thru the relay contacts since all the Bose amps are feed by this relay. If it happens again, try a new relay.
Old Jan 8, 2006 | 10:47 AM
MBZFAN55's Avatar
BMW M850i Gran Coupe
and it works fine.
Ed
I have the same issues on my 2004 S500. No radio. Full blast radio. I even had a "windows" type screen open up in the Comand center, saying "Sound Unavailable". I'm really glad that happened, because I needed confirnation that I wasn't hearing anything. The only good news is that I'm having fewer electronic problems than I had on my 2000 S430.
By the way, restarting the car seems to be the required "fault reset" to fix the malady.
Old Jan 8, 2006 | 11:09 AM
WyattEarp's Avatar
2006 MB C230 SS 6spd, Navi
electronics --> software --> cyclomatic complexity
Old Jan 8, 2006 | 01:46 PM
sped's Avatar
2008 GMC Sierra
Wyatt,
How do I join you gun club??
Ed
