Sponsored by: Innova
How to use cassette adaptor
Old Jan 19, 2006 | 08:21 PM
REDTEES's Avatar
300E 2.5; 2001 SL500
I have an Archos unit (mp3 player and more), Id like to use via a cassette adaptor, however the door for the cassette player (2001 Sl500), is annoying as it beeps when door is opened for a long period of time. Anyone have any solutions for this? I have tried the FM transmitter route, however the sound is not as crisp.
Old Jan 24, 2006 | 08:55 PM
mojomk's Avatar
2006 CLK 350 Cab
Cassette Door
I was successful by using a cassette adapter with a thin wire. I then squeezed the wire in the crevice of the door and closed it tight. It generally will stay closed for weeks at a time. To really do it right, use a warm to medium hot iron and slightly melt the wire flat (only in the spot where it will stick thru the door). You could also use a soldering iron. You also might want to have an extra adapter as a backup. I found the sound to be very good.
Good luck
Old Feb 3, 2006 | 07:45 AM
SkiWithG's Avatar
'01 SLK320
If you can find an adapter with a ribbon-type wire, rather than a round-type wire, it will be easier to fit between the door and body of the head unit. I've had mine in for months without the door popping open. I believe it's a phillips brand purchased on eBay for about $5.00.
BTW, the benz forum has a great thread on permanent installation of a cassette adapter (with pix). Pull the radio, insert the adpter, thread the wire, through the console. etc. The thread is in the R170 forum.
Glenn
Old Feb 3, 2006 | 01:57 PM
cobac's Avatar
2000 E320 4Matic Obsidian Black/Ash
On my E320 without command the door beeps every few seconds if you leave the door open.
I found on the right hand side there is a sensor. The door has a pin on it that hits the sensor when closed.
I took a tiny piece of carboard and pushed it into the hole. Now, I can close the door or leave it open and nothing beeps... Classy isn't it?
