W208 - Battery Question
The time has come to change the battery, one, because it is about 6 years old now and 2, because I want something a bit more conducive to the sound system I relentlessly pump... Thanks in advance...
The good news is that the OEM battries are reasonably priced, and roadside will bring it and make sure everything is properly reset after changing it. You can crank your audio as much as you want because 99% of sound systems use less current than the heated seats.
Optima website says they dont make a battery for a 208 - what did model yellow top did u buy?
My W208 battery just died. Are you saying that I can all the roadside assistance, and they will come to my home with a battery and replace it and reset all the window, seat, sunroof, etc.?
Do they charge for labor?
