Sponsored by: Innova
Ipod background noise?
Old Feb 16, 2006 | 09:01 AM
macgyber's Avatar
2004 SL 350 & E class 200K avantgarde
Ihave a comand(w211,05) and MB original ipod kit. Sounds quality is fine but there is background noise in playing ipod. More volume up, more noise louder.
My ipod is 5th generation ipod, 60G.
How can I solve this problem?
Old Feb 16, 2006 | 06:02 PM
glennbaz's Avatar
2003 SL500
Could you be more specific as to the type of noise. Is it hissing, whinning or popping? Does it change with engine RPM? Does it change with engine on or off?
Glenn B
Old Feb 16, 2006 | 07:57 PM
macgyber's Avatar
Glenn B
Sounds are hissing---mainly related with treble volume
and not related RPM or engine on/off. Always it can be heard.
It is decreased when I down treble volume and increased with treble volume up , but relationship with bass volume adjustment.
Old Feb 16, 2006 | 11:23 PM
glennbaz's Avatar
2003 SL500
Check to see if you have the "AUX" audio input plug in your glove box. If you do plug you audio out form you ipod directly into the aux in the glove box. If the sound is clear then the problem is most likely in the ipod kit. I would bring it back to the dealer with this disclosure.
Glenn
Old Feb 20, 2006 | 11:31 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Also check that your iPod EQ is off, or at least not set to a curve that boosts the treble.
