MSC nav Harness, RCA to RGB
I bought a RCA to RGB converter for $ 200 with the folowing outputs :
Red, Green, Blue, Sync and Ground.
What i would like to do is conect the rgb to the 23 pin conector to get Video in through the navigation harness.
1- can anyone proved the correct pin outs for the 23 conector nav harness
2- Can some provide info on how to activate the Nav button without having a navigator drive ?
No need to a Star scanner because it uses the same concept of the CD changer , lets say u remove the cd changer plug , the result will be No Cd Changer installed.... based on that i think thee is a way to jumo some wires to get a nav installed...
any feedbacks ?
thnks
