'02 c230 coupe: sub install - HELP!
OK, the weather is finally nice here, and I'm ready to install my amp/sub. I have an 02 c230 coupe - with the Bose system, and COMAND 2.0. I saw a few posts on here regarding this issue, but couldn't find any definite answers. I know where to run the power/ground for my amp, this isn't an issue. I have no clue where I should run the remote wire for the amp, or where I can tap into the sound system to get the sound into the amp. I bought a speaker wire to RCA converter in case I need it. My amp also accepts speaker level inputs as well. Do I need to disconnect my factory amp/sub? When I installed my Comand, I noticed that there isnt any speaker wire coming out of the harness because of the bose system. Can I wire the harness to my amp somehow to get signal directly from the COMAND? Any help is appreciated. Thanks!
