Sponsored by: Innova
No sound
Old Jul 1, 2006 | 02:41 PM
BBALLER's Avatar
2011 S550 4matic
No sound
I have a 03 s 500. I turned off my audio when getting out the car, I came back to the car 15 minutes later turned the power back on and now I have no sound from anything. The radio comes on but no sound, cd doesnt even try to play, telephone puts up a error message and voice control cant be heard not even the initial beep sound it makes before saying a command any clue what the problem is???
Old Jul 1, 2006 | 02:46 PM
no_clue's Avatar
.... nothing to brag about, it is a previous model....
Check fuse?
Old Jul 1, 2006 | 02:56 PM
BBALLER's Avatar
2011 S550 4matic
which ones
Old Jul 1, 2006 | 05:23 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Did it re-set after turning off the ignition and removing the key? Did you recycle the power button for COMAND? I had this happen a time or two in my '00 S500, and those steps worked. Ultimately it took a a firmware update to cure my problem.
If not, check the fuses - especially the amplifier fuse. It could be any of several malfunctions (I don't know the detailed electronics well enough - or whether your car has the audio gateway or other components whose fuse failed) - but look for fuses having anything to do with audio. There should be a fuse diagram in your spare tire compartment.
You can also go into the system menu for COMAND and have it re-search for equipment on the fiber optic bus. See Richard Almeida's neat page on COMAND at http://www.mercupgrades.com/comand/C...rvice-Mode.htm and while you're at it check out the main page at http://www.mercupgrades.com/comand/faq.shtml
Good luck. Hope it isn't serious.
Old Jul 1, 2006 | 10:19 PM
BBALLER's Avatar
2011 S550 4matic
how do i check to see if the amp is dead?? I was playing music at a high interval just to see what the systm could do..I turned the car off and removed the key but still nothing, I didnt see a fuse for the amp, but i checked car audio fuse and sound system fuse but there was no problem there. I only checked two fuses could it be any other fuses? or anything that just became unplugged?
Old Jul 2, 2006 | 01:05 AM
no_clue's Avatar
take it back to dealer. your car is only 03', you should have 4 year bumper to bumper warranty
Old Jul 2, 2006 | 10:59 AM
BBALLER's Avatar
2011 S550 4matic
yep i will, i was trying to avoid the stealership. thanks for the help..
Old Jul 2, 2006 | 10:22 PM
BBALLER's Avatar
2011 S550 4matic
[quote=DRTYLNDY]This happened to me as well some time ago. It is the PSE for the phone which causes the problem. Under the rear seat remove the fuses for the radio I believe and plug it back in and it should reset itself. Hope this helps it worked for me.
Johan[/QUOTE
This fixed the problem thanks!!!!!!!!!!!!!!!!!!
