Couple of Audio Questions for new C320
1. Sometimes when I turn off the car, the radio stays on. In fact, the other day, I parked the car for two hours, came back, and the radio was playing. Luckily, the battery wasn't drained. Is this normal?
2. What's with the volume/car speed increase? As I accelerate, the volume increases, and vice versa. I find this really irritating, esp in heavy traffic. Its either too loud or too soft.
Can I override this feature?
Thanks guys.
Newbii
Thanks guys.
Newbii
The radio in my car stays on until I remove the key. Your situation sounds strange. You can turn the radio on without the key in the ignition switch, but it should shut itself off after half an hour.
The speed controled volume has four settings, 0 db, -3 db, -6 db and -9 db. The default setting is -6, while 0 is off. This can only be changed by the dealer using the DAS computer.
