Replace speaker grill cloth - 1997 SL 500
If I find out anything about the top grill, I will let you know.
I have a '98 SL500.
The bottom covers have one sheet metal screw in the bottom, then the cover slides off (toward the dash, I think). Do not try to pry it straight out, or you'll break off the tabs.
Tops are still a problem. I'm pretty sure the door panel has to come off. But let me know if you find out otherwise.
Good luck!
