Sponsored by: Innova
Just installed MB ipod kit
Old Sep 28, 2006 | 06:18 PM
mhh's Avatar
mhh
2012 MB E63 Wagon, 2012 BMW M5, 2010 Porsche 911 Turbo S, 2010 Ferrari 458
I just picked up my wife's e500 wagon from the dealer after getting the MB ipod kit installed. It took them longer than expected (most of the day) - apparently the wagons are trickier to install.
Anyway, I'm still working out what it can and can't do. I don't get the tracks showing on the Comand screen - is that right? Only on the miniscreen on the dash.
I don't know what I was expecting (considering I've read the limitations of the Ipod as a source many times) but the sound isn't much good. With the HK, the CD and radio work fine - Ipod sound is definitely worse. It wasn't the biggest mistake I made this week, but I wouldn't bother if you are thinking of one.
Old Sep 28, 2006 | 08:18 PM
MagicO309D's Avatar
The MB Ipod kit works over the CAN bus so track information can only be viewed on the instrument panel display. (Radio display requires MOST bus input like the CD Changer). Ipod audio is fed into the head-unit through a line-in audio input to the radio.
Some things to try in order to get best possible sound include adjusting Ipod's volume level and then the radio volume (don't over or under drive the radio's line-in audio), select standard instead of Logic 7 mode to reduce over processing of the audio signal, upgrade your Ipod's audio files to higher bit rate files, and adjust tone controls according to your taste.
It'll never sound as good as the built-in CD but it should come close to the sound quality of your FM radio.
Old Sep 29, 2006 | 06:10 AM
mhh's Avatar
mhh
Thanks for these tips - I'll try this.
