Sponsored by: Innova
command retrofit but CD not working
Old Oct 13, 2006 | 09:49 AM
The430man's Avatar
02 CLK 430 -- 2006 S500 --now 2007 CLS550
a few years back I started a job to retrofit a command in my 02 W208. Everything went ok, however, in the middle of the excitement, I never made the CD connection in the back of the command. Recently, I decided to sell the car. The new owner want the CD changer working before he buys it.
So I connected the Pin 5 and Pin 6 as mentioned in here and the CD Changer started working.
The problem is when I turn the Car off for a few minutes and come back, the command system doesn't recognize the CD Changer. If I take the power off from the command and put it back in. It geos into a reset process and the CD starts working again.
Anyone has any ideas what could be wrong ?
Old Oct 13, 2006 | 11:03 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Yep.
Pin 4 ( d2B wake up) is not making a good conection. I had the same problem, I ended up just removeng the locking backshell part of the connector because everytime I lock it in, because of the way pin 4 is locatred, it never would fully seat. So, i just took off the locking part and pushed the C2 connector in manually and never had a problem again.
good luck.. send a post to let me know if that fixed it.
Old Oct 14, 2006 | 09:35 PM
The430man's Avatar
fixed
I think that did it.
Pulled the C1 connections and put them back in. Also, pushed all the pins in all the way on the C2.
Got the CD working, so I drove for about 30 min .... When I got back, turned the car off waited 20 min, turned it back on, it was still working.
Thanks a million ...
The new owner is going to be very happy ... sad to see it go for so cheap, but a new CLS will make forget the pain fast.
