Sponsored by: Innova
W210 phone install w/D2B
Old Oct 21, 2006 | 07:43 PM
John H's Avatar
14 E550, 07 E550, 69 Mach I, 65 Hipo, 66 Fairlane GTA Conv, 66 Fairlane GT
Hi all
I purchased a PSE/Mikbox/Antenna amp from another MBWorld member to add to my 2001 W210. My car had a CD changer but no phone. I hooked up the phone parts but I was lacking the extra D2B cable to add to the loop so I used the one from my CD changer to test the setup. I have the Audio 30 and I am able to use the phone from the head unit. The up/down button on the steering wheel allow me to scroll through my phone book but the phone connect/disconnect buttons give a message that they are non-functional. I'm guessing they need to be set with the dealers STAR system but thought I would ask here first. Secondly, should the phone numbers which show on the head unit also be on the dash display? Thirdly, when I get the extra D2B cable to add to the loop will the system automatically recognize both the phone and CD player.
I've spent a few hours on the net, and MBWorld, researching the MB phones & D2B with limited success. If anybody has any good links please let me know. Thanks in advance.
Old Oct 23, 2006 | 02:02 PM
jman7000's Avatar
2011 E350
I have the same setup in my 2001 w210 . To answer questions 2 and 3;
2) My dashboard also does not recognize the phone. MB has to program it into the system to make the dash work. Everything else works fine so I never saw the need to have it done. You may be different.
3) You system should recognize both automatically as long as you plug them in correctly. I seem to remember a certain order that the devices need to be in. I'm sure i got the info from this forum so search around for fibre device order and you should see something.
Old Oct 23, 2006 | 10:34 PM
John H's Avatar
Thanks jman!
That's what I was hoping to hear.
