Sponsored by: Innova
Puller Power From Engine Compart. to Trunk?
Old Jan 1, 2007 | 09:56 PM
65coupei6's Avatar
'05 C230K Sport
I am adding an amp/sub to my 05 C230K Sedan and was wondering where is a good place to pull the 4 gauge wire thru the firewall. Any place safe to drill a hole or is there somwhere that I can fish it into the passenger compartment?
Old Jan 1, 2007 | 10:54 PM
C24owner's Avatar
'08 E550 4Matic
If you remove the battery you will see that there is a place to run the cable. Each hole is covered with a plug that you’ll need to remove. If you put some wax on the power cable you'll be able to get it thought the hole a lot easier.
Old Jan 2, 2007 | 02:10 PM
65coupei6's Avatar
'05 C230K Sport
Thanks! I will try it.
