Sponsored by: Innova
Dismantling / Cleaning COMAND 2.0
Old May 15, 2007 | 06:32 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
I finally got around to writing a document to go with the stack of photos I took last time I took a comand 2.0 unit apart to clean the laser (fix CD read errors) and the roller (fix the cd eject error)
Its on my mercupgrades website: -
http://www.mercupgrades.com/Comand%2...rticle-20.html
Hope its useful to someone !
Richard
(warning, lots of large pictures ..)
Old May 15, 2007 | 06:37 PM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
Great writeup, thanks for posting.
Old May 31, 2007 | 01:20 PM
atc9443's Avatar
great website Richard!
I just want to ask the following:
Do you know what to do if the COMAND 2.0 ('02 c320) unit does not completely shut down after ignition has shut off?.....the screen shuts off and all button illuminations turns off but the power button and can hear the head unit's fan still run....I've checked the diagnosis on it but no errors...the unit is "standby" mode and not "sleep" mode per-say.
any inputs would be greatly appreciated and I would keep the situation updated.
Thanks,
atc9443
Old May 31, 2007 | 01:29 PM
JohnCL's Avatar
Keep an eye on that power button, as it should turn off. The fan will wake up when you hit your key and you will hear it upon entering the car. Lock your car and watch from the outside to see if it turns off.
Old Jun 30, 2016 | 04:08 AM
Flydutch's Avatar
Merc S55 AMG Kompressor 2003 & S320 1999
Indeed a great write up and it gives me confidence to open the thing up further. My CD rom packed up and I got twice a second hand unit but they both return a CD read error also. I think it must be the lenses being dirty. (Units probably on the shelf a long time), or might it be something else?. I also read your post on reading the hidden screens (menu's) It gives me a list of fault codes though. When you do a reset those codes remain. How do you clear these codes?
