DENISON for 03 SL55 question
The D2B unit connects behind the radio (you can also download the rather vague installation manual from the link I gave) - the location of the GW 500 module itself may vary depending on whether you put the control switch, USB connection, and iPod inputs. I located mine in the center console, and the length of the wires limited where I could put the GW 500 module. However, you may have more options if you put those in the glove box.
I'm not familiar with the amount of space you have behind your radio, or behind the dashboard. idangeli can probably be of more help there. However, a D2B GW 500 does not require reconnecting fiber optics in the trunk, as the MOST unit did in the trunk of my S500 (https://mbworld.org/forums/showthrea...8#post2234888).
Sorry I didn't include this in my first response. Was a bit rushed.
There should be plenty of room behind the headunit. There is a pocket right, behind / below the unit it self.
