Sponsored by: Innova
Need help planning upgrade in C280
Old Jul 8, 2007 | 03:51 PM
faithful_lothario's Avatar
C280
I have a 1995 C280 with the bose system. I wanted to upgrade it and need help in deciding if i need to replace my stock speakers or if they would be fine. My budget is $600 dollars. here is what i was thinking
Speakers: Keep the stock ones since they are bose and sound really clear.
Subwoofer: Get 2 10" kickers subs in a boxed enclosure for my trunk. I heard kicker was good for bass, do you guys have experience with anything better?
Amp: Get a 400W kicker amp with the wiring kit.
head unit: replace my stock bose cassette player with a alpine unit.
Does this sound about right, or should i replace the stock speakers too?
Old Jul 11, 2007 | 03:34 PM
Benzonline's Avatar
99 C43 ///AMG
Keep stock speaker system and add a sub.
Old Jul 11, 2007 | 05:05 PM
C280
should i change the head unit? or would the stock one work?
Old Jul 11, 2007 | 11:12 PM
Benzonline's Avatar
99 C43 ///AMG
Sounds good with stock unit. I purchased a Infinity Basslink and dropped it in the trunk....added more low end without shaking the whole car.
Old Jul 12, 2007 | 04:25 AM
C280
would my stock unit have outputs for subs?
Old Jul 13, 2007 | 10:23 AM
ldangeli's Avatar
EFF YOU JACKIE
No.
Old Jul 14, 2007 | 09:11 AM
eclipsed's Avatar
2002 C32 amg, 1998 328i
You definately should get a new cd player, with mp3/ipod integration inputs as well.
Old Jul 14, 2007 | 01:18 PM
ldangeli's Avatar
EFF YOU JACKIE
What is your ultimate goal? Sound, bass, what? Where are you located?
Old Jul 14, 2007 | 05:53 PM
C280
i wanted my ultimate goal to be good sound with a little bit of bass if i ever needed it. Im located in houston,texas.
Old Jul 16, 2007 | 12:22 PM
ldangeli's Avatar
EFF YOU JACKIE
Start with a new headunit. The increase in power over the stock may be enough for you. Then add a powered sub or amp and sub to the new headunit.
Old Jul 16, 2007 | 03:55 PM
slowrey's Avatar
2006 Mercedes C55 AMG
I'd recommend starting with the least intrusive thing like adding an Infinity Basslink II. After you get that if you're still not pleased with the low end response then replace the HU. The HU is probably not going to make the impact as a dedicated subwoofer.
Old Jul 16, 2007 | 04:57 PM
C280
so would it be okay to get something like a alpine head unit with kicker amp and sub? Would i get a good bass response with kicker amps and subs?
Old Jul 16, 2007 | 05:49 PM
ldangeli's Avatar
EFF YOU JACKIE
Yes. Adding a headunit with sub outputs will make a huge difference, plus if it has a highpass filter, you can remove the bass from the stock speakers and send it to the sub only. This will increase over all sound qualilty.
Old Jul 17, 2007 | 02:53 PM
C280
whats the best amp and bass to get? and can i install it myself?
Old Jul 17, 2007 | 03:03 PM
ldangeli's Avatar
EFF YOU JACKIE
Best is relative. I would stay away from kicker, Pioneer, mbquart, sony, diamond audio and the like.. Stay with a higher end brand, JL, Alpine, RAC, Audisson. It all depends on what you want to spend. Anything you do will be above and beyond what is "factory" installed.
If you are good with wiring and pulling apart you car, yes, you can do it. If you don't know how to wire the power wire with an in line fuse, terminate a ground, open the dash, pull up the door sills, then no, I would say have a good local shop do it.
Old Jul 18, 2007 | 03:15 AM
C280
So i think i am gonna go with the alpine subs, head unit, and amp, with stock speakers. Does that sound good?
Old Jul 18, 2007 | 09:13 PM
jbondox's Avatar
beater with a heater
sure, because tomorrow you willbe doing pioneer, the day after will be sony...
it is all in the install. $10k pair of tweeters will sound like poop if not installed properly...
but your question with alpine, it is pretty good, I use a lot of it, mostly JL though
Old Jul 19, 2007 | 08:29 AM
ldangeli's Avatar
EFF YOU JACKIE
Which Sub, Head unit and amp?
Old Jul 23, 2007 | 11:24 PM
C280
I was gonne pick any type of alpine equipment.
What company has audiophile quality speakes?
Old Jul 23, 2007 | 11:48 PM
slowrey's Avatar
When did MB Quart become crap? They used to be very good when I was competing in IASCA events.
Old Jul 24, 2007 | 12:12 AM
C280
would a high end JL audio setup give me audiophile sound quality?
Old Jul 24, 2007 | 03:25 PM
ldangeli's Avatar
EFF YOU JACKIE
When they were sold to maxsonic they became crap. When they became the #1 brand peddled on the internet, they became crap.
Old Jul 24, 2007 | 03:37 PM
ldangeli's Avatar
EFF YOU JACKIE
No, the amps yes, the speakers no. Define Audiophile for me, in your own words. Sounds is relative, and if you are looking to save money, you aren't going to get "high-end", audiophile goods.
Seas Lotus, Alpine F1, Alpine X-Type Pro, Among others, but for aroun 1000-2000 bucks a set, thats cheap, thats audiophile.
Old Jul 24, 2007 | 07:56 PM
C280
can i just get a JL audio amp and use it with the existing speakers and stock head unit?
