HELP PLEASE!!cd changer/ integrated phone
Please let me know all the details about the fiber optic wire and how to connect the system. Any pictures or websites would be helpful to.
Thanks so much!!!!!!!
Scott
The problem is the configuration of the optical bus. The fiber optics although confusing .... At the radio you probably have two connectors one sayin phone and one saying cd. You need to only use one of these connectors but you might have to take one apart and use the red end from one and the clear end from the other. ( these connectors come apart and the ends only fit in one way so you cant hook it up wrong) Then in the trunk you will need to find the crossover fiber optic that goes from the phone to the cd changer and you will need to take apart the cables in the rear to configure it so the cable comes from the radio to the cd then to the phone and then returns to the radio. The easy way is to do one at a time and indentify them with the light and position them accordingly.
Scott
One caution, I have heard a number of people comment that a dealer may need to configure one's Mercedes with Star Diagnostics after new equipment is installed on the fiber loop. The components apparently need to be in a specific order on the chain. Don't take this as gospel, but, that order might be, amplifier (if you have one), phone second, Voice Recognition third, CD-Player fouth, and so on. I'm not certain if this is true but a dealer might be able to use Star Diagnostics to make everything work regardless of the order.
I have a CD-Player installed by the dealer, and installed a Nokia 6310i phone (with German PSE and all), and I have received not one error message. One can only hope.
Anyway, I am attaching a graphic (sorry I'm not a graphic artist) that displays my understanding of how the fibers can be configured.
Dick Gleason
