Sponsored by: Innova
Change Speakers (Comand D2B)
Old Sep 1, 2007 | 01:46 PM
rubensans's Avatar
Brabus K3
Hello,
I want to change the speakers of my sportcoupe without adding any amplifier.
What do you suggest me? Anyone know the power of the comand internal amp?
I have seen some Alpine S, Alpine R, and Infinity speakers that run at 2 ohms, will it be negative to put them on a system that was designed for 4 ohms?
Old Sep 1, 2007 | 01:54 PM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
Originally Posted by rubensans
Hello,
You can do it easily without an amp. I am not too sure of the rated power of COMAND but it should do just fine as long as you have good quality effecient speakers. The 2 ohm load will work your COMAND more and warm it up a bit. I would stick with 4 ohm if I were doing it.
Focal makes some great efficient speakers, so you may want to look there. Get the highest db rating that you can to maximize your performance.
Old Sep 1, 2007 | 01:57 PM
JohnCL's Avatar
Go take a look HERE
Old Sep 1, 2007 | 02:08 PM
rubensans's Avatar
Brabus K3
Originally Posted by JohnCL
Go take a look HERE
Thanks for your suggestion but it's not easy to find those in Spain.
Best Regards.
Old Sep 1, 2007 | 03:08 PM
rubensans's Avatar
Brabus K3
I have found them but they are too expensive.
http://www.type-rsound.com/type-rsou...raudio&id=5690
http://www.type-rsound.com/type-rsou...raudio&id=5689
Old Sep 1, 2007 | 11:25 PM
JohnCL's Avatar
There are many models in the Focal line, so look around a little more. This is one of the best choices IMO in car audio. What you posted was pretty expensive.
Old Sep 2, 2007 | 03:43 AM
rubensans's Avatar
Brabus K3
Is there a huge diference between 93 and 92 dB's? So is it more easy for Comand to move the 93 dB sepakers than the 92 dB ones?
Best Regards.
Front:
92 db: http://www.type-rsound.com/type-rsou...raudio&id=5657
93 db: http://www.type-rsound.com/type-rsou...raudio&id=5674
93 db: http://www.type-rsound.com/type-rsou...raudio&id=5679
Rear:
92 db: http://www.type-rsound.com/type-rsou...raudio&id=5662
93 db: http://www.type-rsound.com/type-rsou...raudio&id=5669
Old Sep 2, 2007 | 09:53 AM
JohnCL's Avatar
There will not be a huge difference between the two, so if you are at 92 you will be fine. The higher the number the easier they are to drive.
